Odeslat nové téma Odpovědět na téma  [ Příspěvků: 24 ]  Přejít na stránku 1, 2  Další
 Předmět příspěvku: RC systémy PowerBox
PříspěvekNapsal: stř 08.12.2021 18:40
https://www.powerbox-systems.com/produk ... ystem.html
Radio System CORE
Features
26-channel full 4096 step resolution radio control system
extremely secure against interference, genuine redundant 2.4 GHz transmission
extremely long range
redundant PowerBox power supply system with LiIon batteries
high-performance real-time telemetry
up to 800 telemetry values per second
open bus interface for servos and telemetry
sensors and receivers can be set up conveniently from the transmitter
up to four equal-value receivers can be bound to the transmitter
identical high-speed telemetry and reception for all four receivers
robust stick units machined from solid aluminium
quadruple ballraces
hall sensors for sticks and slider controls
20 transmitter controls + 2 optional stick switches
full-color screen with capacitive touch-screen
high-contrast screen, legible in sunlight
ultra-simple programming even for complex models
intuitive menu system with Smartkeys
speech output using licensed Acapella TTS module
speech output without *.wav files – only text input required
supports eight languages with different voices
12 flight modes with priority control
comprehensive timer options
virtual switches
servo cut-off function
receivers can be updated by radio from the transmitter
perfectly balanced transmitter
Alcantara handrests for maximum possible comfort in use
File Manager for exchanging data and backing up models
integral GPS system
Linux PC system for every imaginable expansion
transmitter options and switches installed individually to the customer’s specification
Made in Germany!
Power supply Li-Ion
Channels 26
Servo signal resolution 4096 Steps
Screen TFT - Touch
Weight 1190g
Temperature range -30°C to +85°C
https://www.powerbox-systems.com/typo3t ... c55f1f.png
[ 121.71 KiB | Zobrazeno 2646 krát ]
jyrry.cbcnet.cz
 Předmět příspěvku: Re: RC systémy PowerBox
PříspěvekNapsal: stř 08.12.2021 22:45
Typický nemecký predražený produkt. Dlhý zoznam vlastností a funkcií, ktoré dokážu splniť RC súpravy podstatne lacnejšie. Extremely secure against interference dokážu najlacnejšie digitálne súpravy vysielajúce v pásme 2,4 GHz WIFI. Alcantara handrests for maximum possible comfort in use - žeby toto bol dôvod ceny uvádzanej na stránke Pober box ?
Quadruple ballraces, pre porovnanie Horus X20 S (HD) 10 ložisiek, nastaviteľný chod 60 alebo 45 st,dva vysielacie protokoly (ACCST, ACCESS) umožňujú použitie starších prijímačov (16 kanálov), novších ACCESS 24 kanálov SBUS, prijímačov R9 s dosahom až 10 km.
PříspěvekNapsal: čtv 09.12.2021 7:03
Nekdo asi nechce made in china a libi se mu produkt vyrobeny v eu a priplati si. Coz vede k otazce, v cem je to lepsi nez jeti mimo barevnejsiho displeje?
PříspěvekNapsal: čtv 09.12.2021 8:12
Obrázky: 4
Blog: Zobrazit blog (9)
jyrry si asi koupil nové rádio :)
PříspěvekNapsal: čtv 09.12.2021 10:22
mirOMi píše:
Jsi úplně mimo. :D
PříspěvekNapsal: čtv 09.12.2021 15:25
MomoBrut
Máš aj argumenty?
Netvrdím, že by bol Horus lepší, ale za zásadne nižšiu cenu dokáže v podstate to čo systém od PowerBoxu.
PříspěvekNapsal: čtv 09.12.2021 17:09
Na co argumenty, když píšeš nesmysly, stačí, že ti to napíšu. Jsem dalek toho, abych někoho přesvědčoval o jeho omylech. Je třeba o tom nejdříve něco vědět, než se začne pouštět huba na špacír.
PříspěvekNapsal: čtv 09.12.2021 17:13
MomoBrut píše:
Takže argumenty nemáš, len si si pustil hubu na špacír.
Howgh.
PříspěvekNapsal: čtv 09.12.2021 17:19
tak neco tam asi bude, proc to radio stoji takovou raketu. Me by to treba zajimalo, takze pokud tomu MomoBrut rozumi rad se necham poucit nez abych to slozite do hlouby studoval a hledal rozdily. kuprikladu zajimalo by me, jak dokazi udelat tech 9km dosahu a zda je to garantovane..?
prijimace vypadaj zajimave a nejsou moc drahy (na to ze u nekterych je to vlastne dva redundantni prijimace v jednom jak jsem pochopil) a externi micro gyro je neco, co bych u jeti ocenil jako moznost taky (ne vzdy se podari umistit prijimac do teziste modelu).
PříspěvekNapsal: pát 10.12.2021 14:48
Jako třeba takový Porsche Cayenne taky stojí raketu a dá se říct, že je to předražený německý produkt a že přece úplně stačí Octavia... Přesto jsou lidi, co si to Porsche koupí a docela s vsadím, že toho nelitují i když koukají jak ostatní jezdí v těch octaviích.
třeba voice systém založený na čtení textu místo přehrávání zvukových souborů mi přijde prima vychytávka. A takových věcí se bezpochyby najde víc.
PříspěvekNapsal: pát 10.12.2021 18:13
Ono je to zrovna u tohoto systému s "předražeností" navíc trochu nadsazené, třeba přijímače proti FrSky zase o tolik dražší nejsou a když uvážím, že mají opravdu o dost důkladněji udělanou redundanci (i ty levné), tak mi jejich cena přijde vyloženě v pohodě (až bych řekl vyloženě dobrá, tady se o předraženosti mluvit fakt nedá).
Vysílač je poměrně drahý ten "Core", ale už brzy bude ke koupi ekonomičtější verze Atom, kde cena zas tak tragická není (hlavně když uvážím očekávanou dlouhou životnost). A vychytávek to má opravdu hodně :-)
Popravdě jsem o koupi začal lehce uvažovat, nakonec si asi nechám zajít chuť, ale spíš kvůli obecné snaze "mírnit se a nerozhazovat peníze", zaujalo mne to ale opravdu dost.
PříspěvekNapsal: sob 11.12.2021 23:01
A máte někdo nějaké porovnání s Jeti?
díky
PříspěvekNapsal: ned 12.12.2021 9:02
První (?) rádio s Linuxem? :) Woknousy zkoušela Futaba a prý "žrala i trávu kolem" (výrok jednoho majitele). Jak dlouho pojede na své baterky PowerBox CORE?
PříspěvekNapsal: ned 12.12.2021 12:40
Ona žere i Mz-16 když něco napípávám = když svítí displej. Zhasnuto = vydrží mnohem déle.
To samé "chytré" hodinky co mi dali k narozkám - plný režim = nabíjet denně, úsporný režim = nabíjet po čtyřech dnech.
Podle mého tolik nežere systém, ale ty mohutně svítící zobrazovače.
jyrry.cbcnet.cz
PříspěvekNapsal: ned 12.12.2021 13:41
Nepochybuju, že bude i tento problém vyřešený, jen jsem nikde nenašel (špatně hledal?) údaje o spotřebě, případně nějaké "std výdrži".
