Odeslat nové téma Odpovědět na téma  [ Příspěvků: 639 ]  Přejít na stránku Předchozí  1 ... 37, 38, 39, 40, 41, 42, 43  Další
 Předmět příspěvku: Re: MSH Brain / iKon
PříspěvekNapsal: pát 26.06.2015 19:55
Release Notes:
- 1.0.015 (firmware 1.3.053)
- Overspeed with nitro on Governor: Fixed
- Very small and very slow tail drift: Fixed
- Orientation panel removed from Advanced menu
- Added warning if binding without Spektrum satellite selected
- Removed Aileron/Elevator ratio window.
- Added Hitec S.Bus receiver support
- Corrections and fixes to some instructions
- Small bug fixes and optimization of code
LOGO 550 SX - Brain // SAB Goblin 380 - Brain // HELI-X V6
PříspěvekNapsal: sob 24.10.2015 10:04
New Software 1.0.017 / Firmware 1.3.083 Available
Release Notes
- 1.0.017 (Firmware 1.3.083)
- Solved governor over speed with some Nitro engine
- Now Swashplate Rotation in Advanced menu works correctly
- In Tail drag if you move the cursor to zero, now swashplate instantly removes the correction
- Reduced the Governor engage level from 62,5% of the target speed to 56% of the target speed.
- Added Chinese Simplified in the Language menu
- Added Chinese Traditional in the Language menu
- If Standard Receiver is selected unusable parameters in Governor setup are greyed out
- For all the units now the Servo setup is in panel 2 of the Wizard
- Tail setup wizard simplified with only one “plus” and only one “minus” button for either endpoint direction.
- Tail Precompensation now correct either for aileron and elevator
- Rotor clockwise and rotor counterclockwise buttons added in Swashplate Selection panel and removed the Precompensations panel from Tail Setup panel.
- Now in Advanced -> Gov & Level, moving the “Aileron Angle for over” cursor, the swashplate move in the same direction.
- Connections schemes are now correct when reload data from a MTR file with a different receiver type.
- Opening a ”.MTR” configuration file already opened in a text editor, the application doesn’t crash anymore
- Added infos of SW, FW, Voltage and SN at the end of the new generated MTR file.
- The “Unit Type” selection (Brain/microBrain) is now readed from the connected unit automatically.
- Selecting “Ok” on the messages that inform to close the program (language change, Spektrum binding), now directly closes the program.
- The check at the left of “Full Screen” is now correct if program was open in Full Screen mode.
PříspěvekNapsal: stř 06.01.2016 18:37
Firmware 1.3.084 is out.
It has improvements to the control loop and fixes oscillations problem with BK servos.
PříspěvekNapsal: stř 13.04.2016 20:23
V polovině dubna, tedy každou chvilku, má vyjít aktualizace Braina / Ikona, ve které bude funkční plnohodnotná záchrana, tak jak ji známe z jiných stabilizací. Je připraveno ještě hodně novinek. Vše bude kompletně zdarma pro všechny majitele jednotek.
Ještě něco z novinek:
Some of the rescue features:
-Pulls you out of trouble, levels the helicopter and applies pitch to save the model at the flick of a switch or press of a button
-Advanced learning and dead reckoning algorithms. Constantly adapts to the model and flight conditions (i.e. works with models with extreme vibration)
-Plug and play setup. No tuning required.
-No bench calibration required
-Activated with a free channel or bank
-Optional pitch on rescue, pulls you out of trouble when you need it most
Coming to your brain soon.
Malá ochutnávka.
nebo
PříspěvekNapsal: stř 13.04.2016 20:53
To zni slibne :-) jsem zvedavy, jak to bude chodit....
Goblin 700 3Digi, Goblin 380 3Digi, NeXt RC
Futaba T14SG
PříspěvekNapsal: čtv 14.04.2016 5:09
Tady jsou další videa.
PříspěvekNapsal: čtv 14.04.2016 11:47
Obrázky: 7
Trochu zaspali dobu. Asi maju dlhe vedenie :mrgreen:
Ale vyzera to nadejne len problem s tym ze zachrana najprv heli otoci a moze sa stat ze ked pouzijete zachranu blizko seba tak vam zachrana hodi heli rovno do ksichtu. Asi je bezpecnejsie ked zachrana heli neotaca ale len zrovna do horizontu a stupa.
T-Rex600E@Spirit T-Rex600N@Spirit T-Rex450@Spirit RaptorG4E720@Spirit Chase360@Spirit
 Předmět příspěvku: MSH Brain / iKon
PříspěvekNapsal: čtv 14.04.2016 12:01
Heli to neotaci hned.Napred heli zastavi aby neklesala a az potom otoci.Takze pokud heli klesa v invertu,tak zastavi klesani a otoci a vystoupa.Ma tam byt nekolik rezimu zachrany.Uvidime co nakonec bude ve finalnim fw. Kazdopadne bych rekl ze jakakoliv zachrana je schopna hodit heli proti pilotovi.Kneticka energie heli bude vzdy. Pokud nebude heli stat na miste.
Jo a proc zaspali dobu? Vbar a jini dostali zachranu az minuky rok. Zase takove zaspani v tom nevidim.
PříspěvekNapsal: ned 24.04.2016 17:32
Vydání posunuto na polovinu května. :-(
PříspěvekNapsal: sob 14.05.2016 13:35
Tak něco nového, chystá se Brain 2, vydání celkem brzy :) Tady je pár informací.
b2_legend.jpg [ 60.89 KiB | Zobrazeno 1326 krát ]
When we started work on Brain2 almost 1 1/2 years ago, we kept asking ourselves, what makes a system truly great? For something to earn "legendary" status, it of course comes from the guys using it, and truly loving it. So then the goal is to make a system indispensable. Something intangibly great. Something that exceeds the sum of its parts.
The flybarless system is the heart of the helicopter. It connects to every major component. It's our interface and view into how we connect with our machines. So then we set out to focus on the idea of making Brain2 the ultimate toolbox with a single minded goal of getting the most enjoyment possible out of the machine with the least amount of guessing and frustration.
You guys have seen the work we've done with Rescue. An incredibly complex piece of software in order to make the end user experience a trivial and great one. The new rescue works on Brain1 as a free update and of course Brain2 has it.
But Brain2 has much more. Here's a few highlights of what's new. As we get closer to release, more information will be available.
- 5 new Brain hardware platforms. From small to heavy duty. With some surprising integration
- Faster CPU with hardware acceleration features
- Full high resolution logging capability using an on board non-volatile memory. Brain2 takes logging to the next level in an incredibly useful and meaningful way
- Event logging for high level review of every flight making it easy to diagnose issues
- Full vibration logging on 3 discrete axis, and complete playback of vibration levels from flights
- Real time vibration and logging support (view events as they happen)
- All new rescue feature (also supported on Brain1)
We are still committed to Brain1 development, as can be seen with the free rescue update coming soon. We are also working on things like support for Jeti which will come with firmware updates in the near future. Brain1 also gets real time vibration analysis.
ETA is about 3 weeks.
PříspěvekNapsal: ned 15.05.2016 12:09
Že by nová krabička IKONu která ukazuje že budou čtyři velikosti Brainu/Ikonu?
image_zps01qxh7mk.jpeg [ 124.77 KiB | Zobrazeno 1282 krát ]
image_zpsimidbsc4.jpeg [ 102.54 KiB | Zobrazeno 1282 krát ]
PříspěvekNapsal: úte 24.05.2016 20:18
Brain 2 combo 3.1.jpg [ 61.53 KiB | Zobrazeno 1179 krát ]
Caratteristiche x sito.jpg [ 97.71 KiB | Zobrazeno 1176 krát ]
a ještě okno se záchranou
Rescue 1.jpg [ 155.5 KiB | Zobrazeno 1176 krát ]
PříspěvekNapsal: pon 06.06.2016 19:42
A je to venku!!!!!!!!
Release Notes:
- 2.0.000 (Firmware 2.0.000)
- In some case, when Spektrum satellites are binded by software, setup is defaulted: Fixed
- Added in the “Connections” panel of the Wizard, also schematics for uBrain2 miniBrain2 Brain2, Brain2BT, Brain2HD, Brain2HDBT
- Added in “Demo Mode” the uBrain2 miniBrain2 Brain2, Brain2BT, Brain2HD, Brain2HDBT in the unit selection
- Auto level algorithm completely revised and now is self-configured and auto correct itself
- Removed “Set Level” button from “Unit Orientation” panel of the wizard (now is automatic)
- Removed “Aileron angle for hovering” and “Elevator angle for hovering” cursors (now are automatic)
- Removed “Auto Level” checkboxes from “Flying Style Setup” panel of the Wizard
- Added in the Wizard the new panel “Rescue Mode Setup”
- Added the ability to activate the Auto Level with positive pitch increment (Auto Level or Full Rescue)
- Added the ability to activate the Auto Level with or without positive pitch increment also with another unused radio channel
- Added “Use Rescue” checkbox and “Pitch Rescue increment” and “Time Rescue increment” cursors in Advanced -> Setup n° -> Gov. & Level view
- Added the new panel “Rescue” in Advanced -> Common for dedicated radio channel
- Added “Reversed Pitch” checkbox for model in which the maximum pitch is obtained when the swashplate is all down
- Added a bec test during swashplate and tail movements at end of init. If voltage drop more than 12% an event is recorded (only for unit 2)
- Added the ability to write and edit the instructions in any other language other than those already provided and share the language file with other users
- Removed the “Reset Flight counters” from File menu
- Removed the “Main Counters” from Advanced menu
- Added a new Timer menu with the Main Counters and 4 new timers for components maintenances each with a “partial reset” button
- Added Logs Setup views (only for “2” units)
- Added Real time logs view (only for “2” units)
- Added Recorded Logs view (only for “2” units)
- Added Vibration real time view (and recorded only for “2” units)
- Added Events view (only for “2” units)
- Now Setup are in the same page so it is easier to compare
- When you enter a numeric value the box background become yellow until you finish and push “Tab” key
- In panel 2 “Servo Setup” of the wizard, added a Servo chart list (updated with every new release)
Setting changes to do from previous version:
- If you have reversed the pitch in the transmitter, correct it and use "Revesed Pitch" checkbox in panel 6 "Swashplate Type selection" of the wizard, when using reversed swashplate pitch (swashplate down positive pitch)
- Ensure that in the panel 9 "Unit Orientation" of the wizard, the corresponding icon to the actual unit position is active.
PříspěvekNapsal: pon 06.06.2016 21:03
Zalítnuto, záchrana zachraňuje moc dobře :)
PříspěvekNapsal: pon 06.06.2016 22:53
No vidis, tak si konecne muzes uzivat neco co uz pet roku existuje. :D
Omlouvam se za rypnuti, ale nedalo mi to. Vse v dobrem.
Petr
بتر كوتاتكو
