 Předmět příspěvku: Sonicmodell AR Wing Pro 1000mm
PříspěvekNapsal: čtv 02.09.2021 7:12
https://www.banggood.com/Sonicmodell-AR ... &ID=528924
Description:
Brand Name: Sonicmodell
Item Name: AR Wing Pro
Material: High Quality EPP
Wingspan: 1000mm (39.37'')
Length: 450mm (17.71'')
Wing Area: 18dm²
Version: KIT, PNP (optional)
KIT Empty Weight: 340g
PNP Empty Weight: 500g
Recommended Sonicmodell Power Combo Configuration:
Motor: 2216-1400KV
ESC: 40A w/5V 3A BEC
Servos: 2pcs 9g metal gear servo
Propeller: 2 blades 8x5
Recommended Battery: 4S 3200-3500mAh Lipo, ZOHD Lionpack 18650 4S2P 7000mAh, Click Here
Recommended Flying Capability:
Min. recommended Speed: 31km/h
Max. Speed (with SM power combo): 130km/h
Cruise Speed (with Sonicmodell power combo): 75/80km/h @ 5.5A
Max. Speed Tested Without Structural Failure: 220km/h with no structural damage or twist on elevons
Max. Recommended Takeoff Weight (with SONICMODELL power combo): 1425 grams
Reflex On Elevons: 1.5-2mm at level
Recommended Max. Throws: 12mm
Features:
- The World 1st FPV Wing with dedicated nose camera bay and main hatch bay for DJI HD Air Unit System, no need any cut or DIY to fit the DJI System.
- Aerodynamic designed FPV pocket in both sides of fuselage, with high efficient NACA air cooling system to ensure the FPV gear work in perfect condition.
- Molded by tough EPP material, built-in CF spar for enhancement, super stable flying capability and crash resistance.
- Extra nose and side camera bay and main hatch that compatible with all FPV and AIO cameras in the market.
- Nose camera slot compatible with all HD Auction cameras (for Gopro, DJI, Runcam etc) in the market.
- Multiple tunnels inside all quipment bays, easy to layout wire between each bay.
- Detachable main wing and wing tip, glue-free assembly, portable for outdoor flying.
- Built-in CF rod in the ailerons will give precision and sharp action to your inputs.
- High accurate ball link control system brings agile and quick response in control.
- Special-designed “servo arm built-in” structure will protect your servo arm from impact.
- Large battery bay for extended flight time and more rooms for various Flight Controller.
- Decent rear bay for ESC, isolate interference from other FPV equipment.
- Built-in plate inside fuselage for extra enhancement.
- Extra CA Hinges for DIY will bring you more stiff and agile control.
- Optimized air-cooling design will keep your gear safe from overheating.
English Manual, Click Here
KIT Includes:
SONICMODELL AR Wing Pro KIT with all hardware.
KIT Package Size: 42*31*15.5cm
KIT Package Weight: 1200g
Note: Motor,esc, servos, propeller, battery, charger, transmitter and receiver are not included.
PNP Includes:
SONICMODELL AR Wing Pro KIT with power combo (uninstalled motor, esc, servos, propeller, and hardware.)
PNP Package Size: 42*31*15.5cm
PNP Package Weight: 1500g
Note: Battery, charger, transmitter and receiver are not included.
[ 49.18 KiB | Zobrazeno 5711 krát ]
HB-D8T Brushless
 Předmět příspěvku: Re: Sonicmodell AR Wing Pro 1000mm
PříspěvekNapsal: čtv 02.09.2021 7:41
Ahoj, zakoupil jsem tento model a mám ho již doma verzi PNP (serva kovová asi analogová noname, motor 1216 1400kv, regl 4S 40A, vrtule 8x5 plast pevná nesklopná)
Zvažuji jak osadit tento model, jestli koupit lepší serva digitální corona 9g nebo nechat původní....
Ale na co bych se chtěl hlavně zeptat, napadlo mě osadit motor RCTIMER 5010 360KV a sklopku 10" ale možná až 12" tohle hnací ustrojí by mělo jistě větší účinnost než 1216 1400KV 8x5 vrtule.
Je to blbost dávat na 1000mm křídlo 12" sklopku? Ona by tam vešla... Nezaclání tam směrovky jak u mé větší zety FX61.
Problémy vidím dva jestli nebude klopný moment vrtule moc velký a jestli bude taková vrtule dost rychlá pro tento model?
Model má minimální rychlost 31Kmh asi doporučenou 75-80Kmh a maximální 130Kmh.
Váhu bych se snažil redukovat tak abych to vyvážil a dost, podle toho volil baterii.
Byl radši aby lítalo pomaleji než těch 75-80Kmh líbilo by se mě aby to při 50ti bylo stabilní a hodné klidně pomalejší.
Jsou mé úvahy rozumné nebo vymýšlím hlouposti a mám se držet továrního vybavení?
HB-D8T Brushless
PříspěvekNapsal: čtv 02.09.2021 22:08
Tak sem dnes zabudoval serva ty co byly v PNP asi analogová noname rozměrově kompatibilní s 9g corona.
Chodí pěkně nevrčí.
Zítra budu asi ve stavbě pokračovat, dotaz no motorizaci stále platný pokud mě to tu někdo nerozmluví asi to pak zkusím.
Poznatek: Přímo do prostoru odnímatelného čumáku by šel dát 3-4 článek 18650 1P bylo by možná zajímavé pro variantu nejlehčí jak to rozumně půjde. :D
HB-D8T Brushless
PříspěvekNapsal: pát 03.09.2021 3:58
S tím větším motorem a těžkou vrtulí opatrně, je až na konci toho výčnělku a tudíž má velikou páku vzhledem k těžišti, které nebude zrovna moc vzadu. Nemuselo by se povést to pak vyvážit jen baterkama. A ty nedáš zase tak dost dopředu. Zkusil bych tu hmotnost motoru něčím nasimulovat a jak potom vyjde těžiště.
PříspěvekNapsal: pát 03.09.2021 9:06
Díky za reakci, no budu s tím experimentovat.
Jak sem psal ve svém posledním postu malý 3-4 článek 18650 by asi vešel přímo do toho odnímatelného nosu.
Kamarád mě ze stavbou pomáhá, dnes osadíme motor asi ten originál.
Nějaké ty 18650 mám doma, jak bude osazen motor zkusíme dát do toho nosu 3-4 ks 18560 a uvidíme co na to řekne těžiště.
Kdybych to takhle dovážil mohlo by to být relativně lehké a letět za proud rozumný 1P 18650 článkům.
Mám tu 6Ks 18650 LG HG (něco označení si teď z hlavy nepamatuji celé) jsou to 3000mAh na 30A, 30A po nich chtít nebudu ale mám naměřeno že 2-3C trvale rozumně snášejí.
Takže by to mohlo snad létat 3S nebo 4S 1P přímo v nose nebo třeba na 3S2P kdy bych zkusil dát 3S1P do nosu a 3S do bateriového prostoru.
Bude tam řídící jednotka Matek H743 s proudovým čidlem a telemetrií do radia takže budu mít přehled o proudech a budu moci dle naměřených hodnot optimalizovat počet S a P a letový projev a čas.
Letoun má na sobě označeno CG takže uvidím co řekne stavba, prameny na netu doporučují dát těžiště 5-10mm před značku těžiště pro lepší stabilitu.
HB-D8T Brushless
PříspěvekNapsal: pát 03.09.2021 19:03
Tak to dovážení bude problém.
Na lehouše to nepůjde, se setovým motorem to nedovážím ani s 4s 5200mAh v bateriovém prostoru.
Du zkoušet dál...
Buď spoustu olova do čumáku nebo snad klidně 12Ks 18650 v bateriovém prostoru.
HB-D8T Brushless
PříspěvekNapsal: pát 03.09.2021 19:44
Wormsnake píše:
... nebo snad klidně 12Ks 18650 v bateriovém prostoru.
To jsem měl v modifikované zeta FX61 - 4s3p LiFe 18650... a ta má menší šípovitost, takže motor není na takové dlouhé páce od těžiště.
PříspěvekNapsal: pát 03.09.2021 22:18
Zetu FX61 mám taky, tohle sem koupil abych se naučil nastavovat a létat s letovou jednotkou v plošníku. Chtěl sem malé lehké skladné, a pak dát vyzkoušenou jednotku do FX61 nebo Phoenix 2400.
Sranda je FX61 1550mm dám do váhy se 4s5200mAh.
A tuhle metrovku ne.
HB-D8T Brushless
PříspěvekNapsal: čtv 09.09.2021 10:57
Ahoj, vymodeloval jsem a vytisknul tento unašeč sklopky je tam teď listí camcabon 9.5x5.
Máte někdo zkušenosti s tištenými unašeči je to dostatečně dimenzované?
Je to PLA. Nerad tisknu z PETG blbě se sundává z podložky. Ale mám ho a možná ho udělám z PETG.
Je to tištěno na 50% posuv a teplotu sem zvýšil na 230 stC.
Je to tištěno tryskou 0.25 a vrstvou 0.1 tisk bych nastaven na maximum perimetrů neobsahuje vyplň protože žádná není vše je "perimetrické".
Je to dosti dimenzované?
Možná bych si mohl půjčit cívku CPE HG100 nebo i PC co zvolit?
[ 76.45 KiB | Zobrazeno 4741 krát ]
[ 68.55 KiB | Zobrazeno 4741 krát ]
[ 118.05 KiB | Zobrazeno 4741 krát ]
HB-D8T Brushless
PříspěvekNapsal: pon 13.09.2021 13:30
Tak pokračuju ve stavbě, unašeč sklopky sem vytisknul z PETG HT100 a jeho model doplnil o blokaci překmitu vrtule dopředu k draku letounu. (je to nutné na zeta FX-61 mě vrtule překmitla dopředu a bylo zle) Listí teď graupner 9x6. Listí 9.5x5 camcarbon sem na této verzi unašeče ještě neměl, možná by nepasovalo umístění blokace překmitu...
Vytiskl sem držák jednotky Matek H743 wing nad ní je držák GPS Matek M9N.
Musím ukecat kamaráda co mě ze stavbou pomáhá aby se tu večer stavil má kleště piny a domky pinů které potřebuji nakrimplovat na kablíky z GPS vedoucí do jednotky.
Osadil sem regl Castle Talon 25A a na pevno ho zapájel mezi jednotku a motor ani nevím jestli se bude motor točit správně, když tak to opravím caslelinkem...
Proti origo reglu v zásadě nic nemám ale než spekulovat jak programovat brzdu a hlavně castle je lehčí a snažím se dávat užitečnou zátěž dopředu.
Zadku se snažím ulehčit proto tištěný unašeč s listy kolem motoru a ne až za ním.
V zadním nákladovém prostoru bude asi jen regl zcela ve předu a dal asi nic.
https://www.banggood.com/ZOHD-LIONPACK- ... Country=CZ
Uvažuju že koupím tu baterii co doporučují, s kamerkou runcam2 co mám doma, osazenou v čumáku by to mělo snad jít do váhy...
[ 66.36 KiB | Zobrazeno 4464 krát ]
[ 73.57 KiB | Zobrazeno 4464 krát ]
[ 90.63 KiB | Zobrazeno 4464 krát ]
[ 160.92 KiB | Zobrazeno 4464 krát ]
[ 147.32 KiB | Zobrazeno 4464 krát ]
[ 161 KiB | Zobrazeno 4464 krát ]
HB-D8T Brushless
Uživatelé procházející toto fórum: Žádní registrovaní uživatelé a 20 návštevníků
