PříspěvekNapsal: sob 27.11.2021 5:08
Hello everyone from New Zealand, I am Scott, friend of Tomas (Relax)
My Spreader Bucket and Bambi Bucket in action under Align 600 fly bar mechanics in modified Fun Key fuselage.
PříspěvekNapsal: sob 27.11.2021 9:30
This is perhaps the first time that someone from abroad, moreover from such a distant country, is setting up their own thread on rcmania in the Helicopters – Scale Models section :) .
The spreader, which he planned and built himself, works very nicely, it is effective and efficient. It is a completely original project, which in my opinion no one else in the world has such a functional or rather no one at all. Although there are large models, also used industrially in the chemical treatment of crops, there is used spraying, not granular materials - fertilizers. The machines would be too big and heavy, with liquid chemicals it is possible. Align manufactures machines such as the E-1 or Demeter with internal combustion engines and the necessary GPS navigation.
Like Scott, it occurred to me to make a spray system for my model, and so the Helisica ZK-HIP was created. So we are very similar :D .
The ZK-HIP is still flying for Helisika, they are based on the North Island of New Zealand, and Scott wants to provide information about my Helisika model.
Scott's Spreader model is based on the operated equipment conceptually, although it is not an exact copy of a specific type, it lacks nothing fundamental. The use of material such as coal ash required the installation of a vibrating motor so that the flow of material downwards did not stop. To get a good understanding of the device, it would be good to put detailed pictures here, maybe Scott will.
I will use some elements in the production of my device completely identically, we want to try to change others with Zdeněk thanks to the use of 3D printing. And try to apply other materials than ash, but we also count on it.
PříspěvekNapsal: sob 27.11.2021 20:43
[ 193.11 KiB | Zobrazeno 1995 krát ]
[ 93.89 KiB | Zobrazeno 1992 krát ]
[ 107.99 KiB | Zobrazeno 1992 krát ]
[ 107.23 KiB | Zobrazeno 1992 krát ]
[ 90.77 KiB | Zobrazeno 1992 krát ]
[ 39.91 KiB | Zobrazeno 1992 krát ]
PříspěvekNapsal: ned 05.12.2021 10:41
Hello Scott,
I am Tomas's friend, I am in very often contacts wih him, therefore I can monitor development of his additional devices for his Hughes helicopters, so I know, that this is not easy. But in the final flying with these functional accessories is very attractive.
Your Spreader Bucket is very nicely designed and processed, thanks for your videos and I wish you very succesfully flights with your additionals devices!
Pavel
PříspěvekNapsal: ned 05.12.2021 22:06
pavel123 píše:
Hello Scott,
Pavel
Hello Pavel,
Thank you for the kind words, it is great to speak with new people in the hobby from other side of planet!
It is also great to be able to help wherever I can with my experiences
Regards
Scott 8)
PříspěvekNapsal: sob 11.12.2021 23:25
PříspěvekNapsal: sob 11.12.2021 23:56
You fly the model pretty cleanly and clearly. Anyone who hasn't tried it may think it's easy :-).
PříspěvekNapsal: ned 12.12.2021 0:26
Thank you Tomas, kind words coming from someone highly experienced in the hobby and all that it requires to be successful! :D
PříspěvekNapsal: ned 12.12.2021 10:30
Your videos are very inspiring to me. It's one thing to build something challenging and complicated, it's another to be able to fly perfectly with it, and one without the other is always only half the result. I see great reserves and tasks in flying and setting up VBar.
It's true that I used to be much calmer with a normal helicopter, there weren't those hundreds of hours of work that can be lost for a fraction of a second, it doesn't matter if it's my own mistake or a technical defect. Especially since the fall of last year, it started to show much more, I hardly thought about such a ruse before. It is easy to repair a normal helicopter (although it is not cheap) after repairing it as new. This is out of the question for the scale model :-). So in the spring I want to fly and train more.
PříspěvekNapsal: ned 12.12.2021 10:34
One of my videos from the meeting in Klenčí pod Čerchovem 2018. Also a skillful pilot :-).
PříspěvekNapsal: ned 12.12.2021 11:33
FANTASTIC 8) Smooth flying!!
I need to move to Czech! :D
