 Předmět příspěvku: fertilizer spreader bucket simulation
PříspěvekNapsal: čtv 29.09.2022 11:45
Naposledy upravil ZK-HEL dne sob 01.10.2022 1:49, celkově upraveno 1
 Předmět příspěvku: Re: Recent video
PříspěvekNapsal: čtv 29.09.2022 11:50
This is how I would like to learn to fly someday :-). Simply perfect....
PříspěvekNapsal: čtv 29.09.2022 14:56
Obrázky: 5
What did spreader bucket scatter? A cremated deceased?
PříspěvekNapsal: čtv 29.09.2022 20:52
I know exactly what Scott uses in the spreader, but I'm curious how he will respond to a very non-standard question :-).
 Předmět příspěvku: Fertilizer spreader bucket simulation
PříspěvekNapsal: čtv 29.09.2022 20:55
guchar píše:
:roll:
The spreader bucket was designed and made to simulate aerial topdressing of many different types of fertilizer/grass seed on NZ Farms.
Many have a dust component from the fertilizer manufacture which is what you see leaving a narrow trail of dust.
In most lighting conditions the "spread" of the larger granules in full size operations is not seen, but is sown at a wide "swath" width.
Scott.
PříspěvekNapsal: čtv 29.09.2022 21:17
So the larger - wider work performance is not as well seen as the dusty narrow one, that's right.
I'm also still experimenting but I haven't achieved anything else and it will stay that way. I have the spreader in my study together with the helicopter models, so I didn't want to make it permanently dirty and I won't be using the ashes. With wheat semolina or white breadcrumbs plus mustard seed, the effect is surprisingly good, and the propeller according to the template can shoot it quite far, the track is estimated to be 2 to 3 meters wide. It empties quite quickly however I haven't tried a full charge yet. It can also handle classic fertilizers like cererite, but one start will cost 42 crowns...
Spreading starts at 2:19.
PříspěvekNapsal: čtv 29.09.2022 21:55
Yes, its really down to the basic physics of granule weight which essentially determines how far it can be "flung" against air flow...
I know that in the full size industry here in NZ the fertilizer companies are always striving to make more granulated products as it is very much less wasteful, safer in aerial application, and together with modern GPS mapping on board aircraft fixed wing and rotary, more accurate.
....But in the meantime...for simulation of the more normal ops I want DUST!!! :lol:
PříspěvekNapsal: sob 01.10.2022 10:59
Obrázky: 5
_ I have some of my formal friend, with the last wish spread him over NATURE (after cremation).
In ČR it is legal act, if there are consent of the ground (in CZ = pozemek) owner.
