miťo píše:Pánové, stáhl jsem si do Mobiusu firmware 2.10 a mohu říct, že je to paráda.
Seznam změn v novém firmwaru:
Changes in FW 2.10
1. Moved many global function toggles to each video mode for greater versatility
2. Added Boot Mode Default toggle: Mode 1, 2 or 3 (Photo mode). Photo Mode works with (or without) auto-record and time-lapse functions turned on.
3. Added Date Format toggles for local country standards.
4. Added additional 50, 25, 20, 15, 10, and 5 fps video playback frame rate options.
5. Added Time lapse Movie Function, with fixed 0.25, 0.5, 1, 2, 5, 10, 30 sec. frame capture delay options, or a Custom (hrs:min:sec.) frame capture option. Recordings will play back at the selected video playback frame rate giving native timelapse videos.
6. Added AVI and MP4 movie file format options. AVI is non-standard format and cannot be edited without re-packaging or re-encoding.
7. Added WVGA (848x480) Photo frame size option
8. Changed 60s fixed Time-lapse Photo delay to a Custom setting (days:hrs:min). Camera goes to standby condition with delay >= 5 sec. to conserve battery charge.
9. Added Date Stamp display toggle for Photo Mode
10. Added Audio-only recording mode (voice recorder - no video). Clip length settings do not affect audio recording, which is always continuous recording (unless manually stopped) for 16 hours (with external power) before it will S/S/C to avoid the 4GB file limit. Recording file size is about 3.75MB/min.
11. Added toggles for Web Cam Rotatation (180 deg.) and Web Cam Video Mode (H.264 compression with audio or MJPG without audio). H.264 also offers much smaller file sizes, less latency, and possibly smoother playback on some older display devices.
12. Slowed Down Battery status LED blinking to count flashes easier.
Já mám bohužel smůlu kvůli 64GB kartě zformátované na exFAT. Na update firmwaru budu muset sehnat jinou.
