http://www.rcgroups.com/forums/showatt. ... 1348248639
Popis změn :
1. GUI upgrade
2. Add GPS Lat/Long display
3. Add GPS RTH speed adjustment
4. Add GPS PH parameter setting
5. Improve the transition region between sonar and baro
6. Receiver CH7 switch setting able to use 3 position switch.. Add CH8 input
7. 400Hz Servo update rate added
8. Possible to use your radio transmitter to program your ESC parameters
9. Add gimble Z-axis tracking
10. Add gimble servo center and range limit settings
11. No need to pass Fail Safe and Un-Arm procedure in order to use Gimble.. Use CH6-8 output for Gimble servo control. CH6=Z, CH7 = pitch, CH8 = Roll
12. Fail Safe detection changed to CH5 input.. (Fail Safe is only an auxilary feature.. no guarantee for 100% retrival. During FS, altitude will lock on the height just prior to radio signal loss, no auto go up/down to pre-determined height at the moment. So use it with caution)
13. Battery low volt alarm upper limit change to 4.0V to give more margine for FPV use.
14. Improve smart3D performance
