DJI NAZA pokračování 2
jio
Re: DJI NAZA pokračování 2
#556 Příspěvek od jio »
Není to toto?
1) Basic Gain
Pitch and Roll: To the gains of Pitch and Roll, if you release the Pitch or Roll stick after command stick, multi-rotor should be back to hovering state. If the reaction of multi-rotor in this procedure is too soft (large delay), please increase the basic gain slowly (10%-15% each time) until vibration emerges after you release the stick. Then decrease the gain a little until vibration just disappears. Now the gain is perfect, but the reaction of the attitude change is slow. You can follow the way introduced at the end of this section to tune the attitude gains.
Yaw:The way of tuning the Yaw gain is the same as the way of adjusting the Tail Gyro. If you want fast stick reaction speed, increase the gain, otherwise decrease the gain. However, the spin of multi-rotor is produced by the counter torque force, and the magnitude of which is limited. Therefore, large gain will not produce tail vibration like helicopter, but severe reaction at the start or stop of motors, which will affect the stabilization of the other directions.
Vertical: You use two methods to judge if the Vertical gain is good enough: 1) The multi-rotor can lock the altitude when the throttle stick is at center position; 2) The change of altitude is small during the flight along a route. You can increase the gain slowly (10% each time) until the vibration emerges along the vertical direction or the reaction of throttle stick is too sensitive, then decrease 20% of the gain. Now it is a suitable Vertical gain.
2) Attitude Gain
Attitude gains determine the reaction speed of attitude from command stick, the bigger the value the quicker the reaction. Increase it for sharper and quicker leveling action after command stick released. The control feeling will be stiffness and rigid if the value is too high; and sluggish leveling action and slow braking if too small.
Nefunkční DJI NAZAM Assistant_2.40 pod windows 10
Zdravím.
Pokud někdo používáte Windows 10, tak si dovolím upozornit na problém s DJI_WIN_Driver_Installer a následně i DJI NAZAM Assistant_2.40.
Naza V2 jsem měl konfigurovanou ještě pod W7 a potřeboval jsem doplnit ovládání pro gimbal a při pokusech s Taranisem mi pořád NAZA Assistent nechtěl zobrazovat připojení. Problém jsem hledal v Taranisu a připojení přes S-Bus. Není tomu tak, koptera na vysílačku reaguje bez problémů a motory jde odarmovat. Problém je jen s konektivitou k PC.
Při instalaci ovladače DJI_WIN_Driver_Installer to šlo přes výstražné okno s hláškou "An administrator has blocked you from installing this app. For more information contact the administrator." Potvrdil jsem to a následně nainstaloval i poslední verzi Assistenta. Po připojení na USB ale Assistent nereaguje a modré a červené světlo v něm nebliká. Mám administrátorské práva, nastavil jsem plné práva na DJI adresář a pořád to nefungovalo i když jsem to spouštěl jako správce.
Řešení jsem pak našel na http://www.rcgroups.com/forums/showpost ... stcount=34 a funguje to. Je docela ostudou pro DJI, že to neřeší.
Snad to někomu pomůže.
For people having issues installing the device on Windows 10, I think I have the answer (well it worked for me anyway)
1) First, you have to disable the requirement for drivers to be signed, a guide can be found here for windows 8.1 and Windows 10 users:
http://www.howtogeek.com/167723/how-to- ... d-drivers/
2) Once that has been done, open device manager on your PC and expand the Serial ports section, now if you plug and wait then unplug your naza, you should see one here called USB serial device that will have a COM number of 1-15 possibly after it. This will be your Naza.
3)Right click your COM device, click 'update driver Software', then click 'Browse my computer for driver software'
4) then click 'let me pick from a list'.
5)Click 'have disk' then browse to the location the DJI driver software put the drivers (generally 'C:/Program Files (x86)/DJI Product/DJI Driver vx.xx' or similar. In this folder will be a 3 source folders, you will need to open the Source64 folder then select the .inf file and click open
6) The device driver box should now have DJI USB Virtual COM or similar in, click this then click next. This should successfully install the device driver and allow the software to now see your Naza. If at the last stage you get an error saying the driver could not be installed, you may not have completed step 1 correctly and disabled driver signing, or the driver may be corrupted. In the latter, uninstall the device drivers from the Remove Programs section of control panel, reboot, then install the driver package again from DJI.
If the above has helped, please quote the post and let me know, also any issues please let me know and i'll do my best to help.
If USB Serial Device does not show up in device manager for you or does not disappear when you unplug/plug the USB cable for the Naza THIS GUIDE WILL NOT HELP YOU
Video k tomu na youtube:
https://www.youtube.com/watch?v=YxE6fEBaCaY
caven
#557 Příspěvek od caven »
je potřeba windows restartovat s vypnutou kontrolou podpisu ovladačů a pak je přeinstalovat.
lukinn
#558 Příspěvek od lukinn »
Jio to je ten problém.a problém te angličtiny.
Caven šlo by to trošku víc rozvést třeba do SZ.
Díky moc za odpověď
MaFire
Podivné chování přijímače s NAZE32 rev5
#559 Příspěvek od MaFire »
Ahoj, prosím pomoc s podivným problémem. Postavil jsem copter 250 s ridici deskou naze32. Prijimac mám PWN. Kdyz jsem ho postavil, vse fungovalo az do te doby, dokud jsem ho neodpojil od pc a chtel ho proletet... Najednou nesel ARM. Tak jsem ho znova pripojil k pc a zjistil jsem, ze ac prijimac blika (tavri se, ze je pripojen), tak ridici deska vubec nereaguje na me pohyby (tvari se, ze vubec nedostava signal od prijimace). Zkousel jsem tedy vsechno mozne i nemozne nastavovat, ale naprosto nezavisle na tom to chvili funguje a chvilku ne. Jako kdyby byl nekde spatny kontakt, ale to jsem prekontroloval 3x. Stejne tak jsem zkousel dva jine prijimace se stejnym vysledkem (chyba v prijimaci se teda da asi vyloucit). Cim prosim muze byt zpusobeno, ze prijimac chvilku funguje a chvilku ne? Jak mam postupovat, abych se dobral k tomu v cem je chyba? Uz me nic nenapadá, děkuju za rady.
Amper
Re: Podivné chování přijímače s NAZE32 rev5
#560 Příspěvek od Amper »
Pokud funguje kdyz je pripojeny k PC a odpojeny nefunguje tak je nejspis nejaky hokej v napajeni.
MaFire
#561 Příspěvek od MaFire »
to se stalo jen napoprve... ted uz mi zase chvilku nefuguje vubec, nezavisle na pripojeni k pc´... jen zvesela blika jako by bylo vsechno v pohode... takze šťávu má...
MaFire
#562 Příspěvek od MaFire »
takhle, propojeny k PC (cleanflight) nefuguje vubec, kdyz pripojim aku, tak se rozblika, ale v pc je videt ze stejne nereaguje...
Amper
#563 Příspěvek od Amper »
to to nevim ale pokud by jsi chtel overit ze je prijimac v cajku a generuje signal tak muzes PCcko jako osciloscop
https://www.zeitnitz.eu/scope_en
http://www.instructables.com/id/Use-You ... illoscope/
macil
#564 Příspěvek od macil »
Alebo servo.
Amper
#565 Příspěvek od Amper »
macil píše:Alebo servo.
No, je fak ze PWM neznamená jeden drat ale ja to tak nějak předpokládám. Asi deformace z toho jak stavím ja
MaFire
#566 Příspěvek od MaFire »
Díky zkusím to, teď to zase funguje :) tak až zase odmítne spolupráci
Mr.Holub
#567 Příspěvek od Mr.Holub »
Predpokladam spravne, ze mas RX s Naze propojeny kabliky kde je zem a 5V jen na jednom konektoru a zbytek kanalu ma pouze jeden dratek pro signal?
Overil bych zda jde v dobe kdy se to projevuje do RX proud z NAZE (pokud ma RX kontrolku, poznas snadno, jinak nutno premerit).
Pokud ne, je problem s pripojenim napajeni z NAZE do RX (5V a zem) - spatny kontakt, studenak atp..
lukinn
#568 Příspěvek od lukinn »
Připojení vyřešeno.
Pořídil jsem novou rc soupravu taranis a nejde mě v naze nastavit 3 polohový přepínač na změnu režimů.kdyz ho nastavím v krajní poloze na GPS tak při přepínání mě chodí nesmyslně.Čím se to doladí?
DikY
arachna
#569 Příspěvek od arachna »
... a co ti pri prepinani ukazuje posuvnik v NAZA asist. /Basic/RC ???
Musi presne ukazovat na pozici, kterou ocekavas po prepnuti. Pokud je na rozhrani modu, tak to muze blbnout.
Vetsinou je potreba subtrimem na kanale, ktery mas pro "U" (ControlModeSwitch) trochu poladit relativni stred prepinace ... :wink: 8)
martin.b
#570 Příspěvek od martin.b »
Ahoj, potřeboval bych schéma propojení mezi NAZE32 rev 5 a JETI přijímačem přes EX BUS. Zkouším to v BETA FLIGHT a moc se mi to nedaří. Nejsem si jistý, zda mám správně dané kabely. Díky Martin
Goblin 700 spirit ,Kraken 700 spirit ,msx 64 ,jeti DS14
