Regulatory Turnigy marine 50
rejsek.zdiby
Ahoj,nezabyva se tu nekdo programovanim techto regulatoru? Koupil jsem dva do remorkeru a maji tzv. Double click ochranu. To znamena ze pri prechodu z pred do zad se musi paky presunout do zpatecky,pak neutralu a pak az couva...coz neni moc zadane.nenasel by se nekdo,kdo by to nejak vypnul?diky moc.
rejsek.zdiby
Re: Regulatory Turnigy marine 50
Spletl jsem se,jde o Marine 35 a v navodu je to popsano takto: Forward and backward mode use doubleclick method to activate the backward action. When you move the throttle stick from forward zone to backward zone for the first time (this is the first click),the esc begins to brake the motor,the motor speeds down but it is still running, not completely sttoped, so the backward action is NOT happend now. When the throttle stick is moved to the backward zone again (the second click), if the motor speed is slowed down to zero, the backward action will be occurred. The double click method can prevent mistakenly reverse event.
