MarthiR píše:Ten bude asi slabý
Dovolím si citovat z recenzí na ten motor Turnigy:
8 Flights on a Sebart Wind S 50 E 6S 5000mA/h, APC 16x10 E prop, 100 A yep ESC , yes it's heavy but moved cg forward and OMG Does this power train pack a punch goes vertical straight after take off at 75pcnt throttle was towing with the idea of getting a Hacker motor , thank god I saw sense and saved myself a packet . Motor sounds great and power is instant great motor what ya waiting for just get one ordered you won't regret it ! Thanks again Hobby King for A 1 service and product.
Váha toho modelu bez baterie je 2700g
I use this Engine with a Cherry wood 13x8 propeller , the Turnigy Brushless ESC 85A w/ 5A SBEC, and 2 Lipos with 3600mAh in a row. The Thrust is Amazing. My Plane with an weight over 4.4 kilograms was pushed to the Sky like a Rocket. I would always Order this Motor again. I Have no Problems with this Engine after 20 Flights. So Hurry up. This Engine is Amazing !
Jelikož psal, že váha modelu bude cca. 3kg, tak bych tento motor viděl jako dostačující.
