Raptor G4 Nitro:
Fuselage Length: 1354mm
Fuselage Width: 221mm
Height: 462mm
Main Blade Lenght: 690 - 720mm
Main Rotor Diameter: 1584mm (690mm blade)
Tail Blade Lenght: 105mm
Tail Rotor Diameter: 280mm
Main Gear: Helical 111T (Mod 1.0)
Motor Pinion: 14T (standart)
Gear Ratio: 1:7.92:4.67
Fully Equipped Weight: 4400 gr (w/o fuel)
Fuel Tank Capacity: 650cc
Header Tank Capacity:60cc
Raptor G4 E720:
Height: 462mm
Main Rotor Diameter: 1604mm (710mm blade )
Main Gear: Helical 115T (Mod 1.0)
Motor Pinion: 12T (standart)
Gear Ratio: 1:9.6:4.67
Fully Equipped Weight: 3750 gr (w/o battery)
Room for Batter: Max. 215 x 52 x 105 mm
Motor: OBL 50/05-90H Outrunner 500 KV
