Futaba bezpádlo CGY750 - tipy, triky, zkusenosti
Re: Futaba bezpádlo CGY750 - tipy, triky, zkusenosti
Tady je nastavení CGY750 na 700 od Nicka Maxwella
Zisky pro vis - 1680 rpm
Rud: 39%
Ail: 50%
Ele: 58%
Zisky pro 3D - 1920 rpm
Rud: 40%
Ail: 60%
Ele: 80%
Rud Gyro Basic:
vše standard kromě F.F: 13% na každou stranu kolektivu
Expert AIL:
-EXP. AVC: -20%
-AIL. Dlin A/B: 0 n
-AIL. Dout A: 3 n; B: 2 n
-Stop. Dly: 100%
-AVCS. DMP: 109%
-CNT. Feel: 5 n
-Rate. CST: 90%
-ANG. Rate: 100%
-I. Gain: 31%
-D. Gain: 200%
Expert ELE:
-EXP. AVC: -20%
-ELE. Dlin A/B: 0 n
-ELE. Dout A: 9 n; B: 11 n
-Stop. Dly: 100%
-AVCS. DMP: 114%
-CNT. Feel: 5 n
-Rate. CST: 106%
-ANG. Rate: 100%
-I.Gain: 31%
-D.Gain: 200%
SwashSet Basic:
-Swash Type: H 3-120
-Servo Type: DG:1520
-Heli Size: 600-700
-FLT. Mode: -5-
-AIL. Rev: Normal
-ELE. Rev: Reverse
-PIT. Rev: Reverse
-AIL/ELE/PIT. ntr: +0 us
-AIL. Rate: +50%
-ELE. Rate: +56%
-PIT. Rate: +48
-SWS. Ring: 112%
-PHASEequa: Off
-Rot.Equa: On
-EQUA.Dir: Normal
-ROT.Trak: -0.6%
-ROT.His: 16dgt
Expert:
-PIT>AIL: A/B: 100%
-PIT>ELE: A/B: 100%
-AIL>PIT: A: 124%; B: 108%
-ELE>PIT: A/B: 50%
-ELE>AIL: A/B: 50%
Největší vliv na nastavení má podle něj Delay. Nastavuje tedy Dly.In pro AIL i ELE na 0. Potom zvyšuje Dly.Out tak, aby AIL i ELE zasekávalo a nehoupalo.
Zisky pro RUD, AIL, ELE nastavuje standardně tak, aby byly co nejvyšší bez oscilace.
Rud: 39%
Ail: 50%
Ele: 58%
Rud: 40%
Ail: 60%
Ele: 80%
Rud Gyro Basic:
Expert AIL:
-EXP. AVC: -20%
-AIL. Dlin A/B: 0 n
-Stop. Dly: 100%
-AVCS. DMP: 109%
-CNT. Feel: 5 n
-Rate. CST: 90%
-ANG. Rate: 100%
-I. Gain: 31%
-D. Gain: 200%
Expert ELE:
-EXP. AVC: -20%
-ELE. Dlin A/B: 0 n
-Stop. Dly: 100%
-AVCS. DMP: 114%
-CNT. Feel: 5 n
-Rate. CST: 106%
-ANG. Rate: 100%
-I.Gain: 31%
-D.Gain: 200%
SwashSet Basic:
-Heli Size: 600-700
-FLT. Mode: -5-
-AIL. Rev: Normal
-ELE. Rev: Reverse
-PIT. Rev: Reverse
-AIL. Rate: +50%
-ELE. Rate: +56%
-PIT. Rate: +48
-SWS. Ring: 112%
-PHASEequa: Off
-Rot.Equa: On
-EQUA.Dir: Normal
-ROT.Trak: -0.6%
-ROT.His: 16dgt
Expert:
-PIT>AIL: A/B: 100%
-PIT>ELE: A/B: 100%
-ELE>PIT: A/B: 50%
-ELE>AIL: A/B: 50%
bavarianDemon 3X a 3SX
Tak Fujtajblí bezpádlo na cestě domů
Jeti model
MS Composit
Bavarian Demon
MS Composit
Bavarian Demon
Dej vědět.
Určitě dám, ještě k tomu musí dorazit Rave a další zbytečnosti, jako listy a tak
Jeti model
MS Composit
Bavarian Demon
MS Composit
Bavarian Demon
- OPR
FrenkyL píše:Určitě dám, ještě k tomu musí dorazit Rave a další zbytečnosti, jako listy a tak
ËWRYBADY
FrenkyL píše:Tak Fujtajblí bezpádlo na cestě domů
Hurááá. Hned jak to budeš mít naladěný máš mě tam !!!
Chopso 7EW , MSH PROTOS 500 , Torsion SOLID Blades
Futaba 8FG
Futaba 8FG
ËWRYBADY píše:FrenkyL píše:Tak Fujtajblí bezpádlo na cestě domů
Hurááá. Hned jak to budeš mít naladěný máš mě tam !!!![]()
To se ještě uvidí
Jeti model
MS Composit
Bavarian Demon
MS Composit
Bavarian Demon
ËWRYBADY
Tak nakonec Radixy...
Jako přehozený to máme za 3 minutky..
Myslím, že to přežiju
Futaba 8FG
Futaba 8FG
ËWRYBADY píše:Tak nakonec Radixy...Jako přehozený to máme za 3 minutky..
CY vrtulník, tak i CY listí
Jeti model
MS Composit
Bavarian Demon
MS Composit
Bavarian Demon
CY vrtulnik, CY listi a nemas tam CY bezpadlo Total G? Neni to prohresek proti bonmotu???
Mohl by mi nekdo popsat, jak funguje u CGY750 u kridelek a vyskovky Delay out A a B ? Jaky je v tom rozdil, co presne to dela na vystupu ?
Jedna se o zpozdeni vystupu regulace ze senzoru ? Jakym zpusobem je provedeno zpozdeni, "natahnutim vzorku" v case, nebo napr. pockanim n cyklu, nez se data dostanou na vystup ? Je zpozdeni aplikovano na cely vystup nebo jen na nekterou slozku regulace, napr. proporcionalni ?
Spirit System
Z manualu jsem vycetl, ze se jedna o zpozdeni kniplu, ne regulace, smerem zpet k neutralu. Vubec ale nepisou, co je A, B ?
Spirit System
A je jedním směrem a B je druhým směrem. Takže třeba u výškovky můžeš mít jiné zpoždění dopředu a jiné při pohybu kniplu dozadu.
Co vím, tak to funguje jako zpoždění regulace jako takové.
boZZda píše:A je jedním směrem a B je druhým směrem. Takže třeba u výškovky můžeš mít jiné zpoždění dopředu a jiné při pohybu kniplu dozadu.
Aha diky, v tom pripade ale nechapu, co presne dela Delay In
Spirit System
ZeXx86 píše:boZZda píše:A je jedním směrem a B je druhým směrem. Takže třeba u výškovky můžeš mít jiné zpoždění dopředu a jiné při pohybu kniplu dozadu.
Dly Out funguje jako zpoždění zastavení vrtulníku z pohybu. Dly In funguje jako zpoždění akcelerace vrtulníku do pohybu. Nejlepší je míst In = 0.
Pomocí Out se zvyšováním odstraňuje houpání. Na křidélkách cca 4-5, na výškovce cca 10-12.
