Blade MCPX
Vrtulníky do velikosti 450
blade120
Blade MCPX
#1 Příspěvek od blade120 »
Na Toyfair 2011 bol predstavený nový Blade MCPX (micro flybarless, 235 mm)
http://www.heliplane.net/2011/02/toyfai ... zon-hobby/
blade120
#2 Příspěvek od blade120 »
Video
http://www.youtube.com/watch?v=3it57mjJ ... _embedded#
P.S. Myslím že T-REX 100 bude mať problém.
Gattor
#3 Příspěvek od Gattor »
to je hodne hezky. moc se mi libi, chci ho taky. cena bude asi okolo 4-5ti tisic (BNF). vyleze to kolem kvetna. mam spravne informace?
T-Rex 500 ESP (GP780), T-Rex 450 Pro (MicroBeast), T-Rex 250 (FM), Blade mCPx - DX7
avalanche8
#4 Příspěvek od avalanche8 »
Fakt pecka,myslim ze brzo spouta z nas proda MSR a poridi tuhle novou helinku,je super :D
lastfever
#5 Příspěvek od lastfever »
sakra a to sem pred vanocema kupoval MSR, ja chci tohle!!!
Lukash
#6 Příspěvek od Lukash »
Tak to je moc. Tohle by mně asi neomrzelo po měsíci jako to MSR.
off
#7 Příspěvek od off »
Sakryš, nejde mi tu YouTrubka - vidím dobře, že je to šestikanál?
off
#8 Příspěvek od off »
Ha...
http://www.horizonhobby.co.uk/aeroonlin ... .html#info
OVERVIEW
The Blade mCP X the lightest flybarless helicopter in its class. An ultra-micro collective pitch helicopter, it is designed for intermediate to advanced pilots. More specifically the mCP X will give transitioning pilots a more agile and capable collective pitch heli that will give them the confidence to master indoor aerobatics without the hesitance which comes with a larger outdoor only platform. Obviously the lower cost involved also makes it a much more economical alternative when learning.
It comes out of the box 100% factory built and equipped with a factory-installed Flybarless 3-in-1 Control Unit with Spektrum 2.4GHz DSM receiver, ESCs, gyros and a 2.4GHz DX4e DSM2 transmitter.
As well as the heli itself in the box are two 1S 200mAh 25c batteries, a single port charger with AC adapter and a 1s High Current Ultra-Micro Battery adaptor lead. Also included are a pair of optional fast-flight main rotor blades for when confidence has grown. Transmitter batteries are also included.
Using an integrated Flybarless system, this awesome little heli to gets up in the air without a mechanical flybar. The benefits of this system provides reduced drag on the main rotor head which results in more power, longer flight times, and provides the pilot the best of both worlds between stability and agility.
The Blade mCP X is the ultimate ultra micro heli experience. Its revolutionary GX3™ flybarless system, the most advanced on any ultra micro heli, delivers a level of power and cyclic response that is second to none. This, combined with the exceptionally small, lightweight mCP X airframe makes it possible to precisely fly extreme aerobatics in spaces no larger than a living room or conference room.
Specifications
Type: Flybarless Ultra Micro Helicopter
Main: Rotor Diameter 245mm (9.65 in)
Length: 235mm (9.25 in)
Height: 93mm (3.65 in)
Tail Rotor: 36.5mm (1.4 in)
Weight: 45.5 g (1.6 oz)
Batteries: 1S 3.7V 200mAh 25C LiPo
Charger: E-flite™ Celectra™ DC LiPo balancing charger and AC
power supply plus High-Current Ultra Micro Battery Adapter
Lead
Radio (RTF): Spektrum™ DX4e 2.4GHz DSM™ transmitter with 4 AA
batteries
BNF: 4+ Channel DSM2 Aircraft transmitter required (BNF)
off
#9 Příspěvek od off »
U sta hromů, jak dělají CP na čtyřkanálu?
corona
#10 Příspěvek od corona »
Tři serva, hlavní a ocasní motor - tak buď kecají a není to čtyřkanál, nebo jde o nějakou mixáž...
Milošek
#11 Příspěvek od Milošek »
Když je gyro vestavěné tak to pátej kanál nepotřebuje.Stačí čtyři.Zbytek udělají mixy.Podle mne.Vypadá to moc zajímavě.
zablabla
#12 Příspěvek od zablabla »
blade120 píše:Video
A sakra, to je nářez, doufám že budou nějaký prémie :lol: :lol: to musím mít.
Blade msR, mcpx, Trex 250 FBL + DX6i ;Trex 250,Trex 500 FBL + T8FG
demolátor
#13 Příspěvek od demolátor »
[quote="off"]Ha...
Kde jsi to sehnal?? Rad bych se něco dozvěděl taky o blade 45O.
Dik
Miniprotos BeastX
Protos 500 V-bar
Spektrum Dx7
blade120
#14 Příspěvek od blade120 »
off
#15 Příspěvek od off »
Milošek píše:Když je gyro vestavěné tak to pátej kanál nepotřebuje.Stačí čtyři.Zbytek udělají mixy.Podle mne.Vypadá to moc zajímavě.
Dovolím si nesouhlasit, pro plné řízení potřebuju předat 5 informací: cykliku (=klonění+klopení), vrtulku (bočení), kolektiv a otáčky. Takže tam musí být nějaká finta - napadá mě třeba spouštění motoru prvním pohnutím kolektivu a vypnutí stažením kolektivu až dolů na nějakou dobu, nebo nějaký mazaný mix kolektivu a otáček nebo tak něco...
Zpět na „Heli - do 450“
