Sestavy F3P 2017 - návrh - popis obratů a Aresti ADVANCED SCHEDULE AA-17 (2016-2017)AA-17.01 Tilted Humpty-Bump
From upright, pull through a ½ loop, into inverted flight, pull trough a ½ loop, exit upright.
AA-17.02 Stall Turn From upright, pull through a ¼ loop into a vertical upline, perform a stall turn into vertical downline, pull through ¼ loop, exit upright.
AA-17.03 Horizontal Circle 8 From upright perform a ¼ horizontal circle, then perform immediately another (full) circle in the opposite direction, then finish the remaining ¾ of the first circle, exit upright.
AA-17.04 Half Horizonal Square Circle From upright, perform a ¼ horizontal circle with wings level, perform a ¼ horizontal circle with wings level, exit upright.
AA-17.05 Roll Combination with consecutive ½ roll, ½ roll From upright, perform consecutively a ½ roll and a ½ roll in opposite directions, exit upright.
AA-17.06 Knife-Edge Humpty-Bump From upright, pull through a ¼ loop into a vertical upline, perform a ½ knife-edge loop into vertical downline, pull through a ¼ loop, exit upright.
AA-17.07 Cobra Roll with ½ roll, ½ roll From upright, pull through a 1/8 loop into a 45° upline, perform a ½ roll, pull through a ¼ loop into a 45° downline, perform a ½ roll, exit upright.
AA-17.08 ½ Horizontal Circle From upright, perform a ½ horizontal circle, exit upright.
AA-17.09 Vertical Upline with consecutive two ½ rolls From upright, pull through a ¼ loop into a vertical upline, perform consecutively two ½ rolls in opposite directions, push through a ¼ loop, exit upright.
AA-17.10 ½ Square Loop From upright, push through a ¼ loop into a vertical downline, push through a ¼ loop, exit inverted.
AA-17.11 Loop with ½ roll From inverted, perform a loop with a ½ roll integrated in the top 90°, exit upright.
PRELIMINARY SCHEDULE AP-17 (2016-2017)AP-17.01 Double Immelman with roll, roll From upright, pull through a ½ loop, perform a roll into inverted flight, pull trough a ½ loop, perform a roll, exit upright.
AP-17.02 Figure M with ¼ roll, ¼ roll From upright, pull through a ¼ loop into a vertical upline, perform a ¼ rolls, perform a stall turn into vertical downline, push through a ½ loop into a vertical upline, perform a stall turn into a vertical downline, pefom a ¼ roll, push through ¼ loop, exit inverted.
AP-17.03 Horizontal Circle 8 with two rolls From inverted perform a ¼ horizontal circle while performing the first ¼ of consecutive two rolls to the outside, then while continuing the rolling (¼ of the rolls per ¼ of the circles), perform immediately another (full) circle in the opposite direction, then, while continuing the rolling accordingly finish the remaining ¾ of the first circle, exit inverted.
AP-17.04 ½ Horizonal Square Circle with ½ roll From inverted, perform a ¼ horizontal circle with wings level, perform a ½ roll, perform a ¼ horizontal circle with wings level, exit upright.
AP-17.05 Roll Combination with consecutive 1 ¼ roll, 1 ¼ roll From upright, perform consecutively a 1 ¼ roll and a 1 ¼ roll in opposite directions, exit upright.
AP-17.06 Knife-Edge Humpty-Bump with ½ roll From upright, pull through a ¼ loop into a vertical upline, perform a ½ roll, perform a ½ knife-edge loop into vertical downline, push through a ¼ loop, exit inverted.
AP-17.07 Knife-Edge Cobra Roll with ¼ roll, ¼ roll From inverted, push through a 1/8 loop into a 45° upline, perform a ¼ roll, perform a ¼ knife-edge loop into a 45° downline, perform a ¼ roll, pull through 1/8 loop, exit upright.
AP-17.08 ½ Horizontal Circle with four consecutive ¼ rolls From upright, perform a ½ horizontal circle while integrating consecutively four ¼ rolls, exit upright.
AP-17.09 Vertical Upline with consecutive two ½ torque rolls From upright, pull through a ¼ loop into a vertical upline, reduce flying speed to zero in the middle of that line, perform in this position consecutively two ½ torque rolls in opposite directions, then accelerate, push through a ¼ loop, exit upright.
AP-17.10 ½ Square Loop with consecutive two ¼ rolls From upright, push through a ¼ loop into a vertical downline, perform consecutively two ¼ rolls pull through a ¼ loop, exit upright.
AP-17.11 Knife-Edge Loop with ¼ roll, ½ roll, ¼ roll From upright, perform ¼ roll, perform a knife-edge loop with a ½ roll integrated in the top 90°, perform a ¼ roll, exit upright.
FINAL SCHEDULE AF-17 (2016-2017) AF-17.01 Knife-Edge Humpty-Bump with ¾ roll, ¾ roll From upright, pull through a ¼ loop, perform a ¾ roll, perform a ½ knife-edge loop, perform a ¾ roll, exit inverted.
AF-17.02 Figure 9 with roll From inverted, push through a ¼ loop into a vertical upline, perform a roll, pull through a ¾ loop, exit upright.
AF-17.03 Vertical 8 with roll integrated From upright, push through a loop, push through another loop while performing a roll integrated in the last 90° of the first loop and in the first 90° of the second loop, exit upright.
AF-17.04 ½ Horizonal Circle with consecutive eight 1/8 rolls From upright, perform a ½ horizontal circle while integrating consecutively eight 1/8 rolls, exit upright.
AF-17.05 Horizontal Double Immelmann Circle with ¼ roll, ½ roll integrated, 1 ½ roll, ½ roll integrated, 1 ½ roll, ¼ roll From upright, perform a ¼ roll in the center into a sustained knife-edge flight, perform a ½ circle while performing a half roll to the outside integrated, immediately followed by a 1 ½ roll in opposite direction, perform a sustained knife-edge flight, perform a ½ circle while performing a ½ roll to the outside integrated, immediately followed by a 1 ½ roll in opposite direction, perform a sustained knife-edge flight, perform a ¼ roll in the center, exit upright.
AF-17.06 Knife-Edge Top Hat with two consecutive ¼ rolls From upright, pull through a ¼ loop into a vertical upline, perform a ¼ knife-edge loop into a horizontal knife-edge flight, perform a ¼ knife-edge loop into a vertical downline, perform consecutively two ¼ rolls, push through a ¼ loop, exit inverted.
AF-17.07 Double Fighter Turn with ¾ roll, ¾ roll From inverted, push through a 1/8 loop into a 45° upline, perform a ¾ roll, push through a ½ knife-edge circle into a 45° downline, perform a ¼ knife-edge loop into a 45° upline, push through a ½ knife-edge circle into a 45° downline, perform a ¾ roll, push through a 1/8 loop, exit inverted.
AF-17.08 ½ Horizontal Square Circle with ¼ roll, two consecutive ½ rolls, ¼ roll
From inverted, perform a ¼ roll, push into a 1/4 horizontal circle, perform consecutively two ½ rolls in opposite directions, push through a ¼ horizontal circle, perform a ¼ roll, exit upright.
AF-17.09 Barrel Roll From upright, pull through a 1/8 loop into a 45° upline, perform a barrel-roll with 45° spiral pitch, perform a 45° upline, push through a 1/8 loop, exit upright.
AF-17.10 ½ Square Loop From upright, push through a ¼ loop into a vertical downline, push through a ¼ loop, exit inverted.
AF-17.11 Clover Leaf with ½ torque roll, ¾ torque roll, ¾ torque roll From inverted, push through a 1 ¼ loop,while reducing flying speed to zero, perform a ½ torque roll, then accellerate to push through a loop, while reducing flying speed to zero, perform a ¾ torque roll, then accelerate to push through a loop.
